heated seats !
Old Nov 28, 2008 | 08:56 PM
pilsner's Avatar
Default heated seats !
ok, when i push the button to warm up my butt nothing happens. the lights illuminate but my butt stays cold!
is there a fusable link or some such that i need to replace?
thanks
Old Nov 28, 2008 | 09:03 PM
Default RE: heated seats !
Check the relays under the seat.
Old Nov 28, 2008 | 10:17 PM
Willie 00D2's Avatar
Did your Discovery come with heated seats or did you add the switches? Mine did not come with heated seats. I bought the activation kit, the light on the button lights up. But in turned out there were no heating elements under the leather.
Willie
Old Nov 29, 2008 | 07:44 PM
pilsner's Avatar
it was a stock feature. it worked great last winter, but no dice when i pushed the button this winter.
relays under the seat? where do i look under the seat to find relays and what am i looking for to indicate if they are blown or not?
thanks
Old Nov 29, 2008 | 07:54 PM
Do both sides not work?
No way that I know of to tell if the relays are good or not.
If the passenger side works then switch relays from side to side, if it then works you need new relays, unless your wife likes a cold butt.
Old Nov 29, 2008 | 10:36 PM
AK Rover's Avatar
I looked under the seat of my D1 trying to solve the same problem. I found 4 relays corresponding to the 4 motors for the power seats. I never found a relay for the heated seats. Most likely the problem is that the heating element has an open section it and no continuity in the circuit causing it not to work. It is common for the heating elements in seats to break on the side closest to the door where your butt hits first as you enter. I actually pulled the seat cover on the driver seat in a Saab I had and soldered it back together and got it working. I haven't dug that deep into the Rover seat yet to see if that fix will work but I can't see why it wouldn't. Just make sure to wrap the repaired solder joint with electrical tape or similar to keep the seat foam from catching fire.
Old Nov 30, 2008 | 09:24 PM
pilsner's Avatar
same problem on both sides - light comes on but butt stays cold x 2.
suggestions please?
Old Nov 30, 2008 | 11:44 PM
pilsner's Avatar
Default RE: heated seats ! and other electrical issues
in addition to my heated seats not getting warm the compass in my rear view mirror is out.
is there a fuse they have in common.
no other issues that i can remember - the dome lights, dash lights, radio, windows, and climate control all work.
thanks
jaynes
Old Dec 2, 2008 | 02:12 PM
pilsner's Avatar
is there any fuse comonality between the heated seats and the mirror compass by chance? i glanced in the fuse box under the hood and saw no thing that was blown.
ugh! hate the cold butt in the morning...
Old Dec 2, 2008 | 04:37 PM
Disco2Guy's Avatar
Did you check the fuse panel under the steering wheel? I'd look there first for a fuse for the seat heater before the engine bay.
booper169
Nov 9, 2010 09:10 AM
tophetec
Dec 2, 2006 01:03 PM
newBrover
Nov 14, 2006 12:50 PM
sydneysport
Oct 1, 2006 09:18 PM
sydneysport
Sep 24, 2006 11:33 AM
