Heated Seats and CDL Disco2
The heat in the seat mysteriously began working while I was driving last night. Typical. On the CDL, I pulled the housing from the donor, along with switches/sensors but the main shaft with gears would not come out. Maybe if I pulled the rear output flange it will slide out forwards. In the RaVE the gear sets and output shaft look identical. Is it possible to use the modified housing with my current transfer case output shaft and diff component? I read somewhere that josh salas said it was better to do it this way rather than swap the whole shaft because of the trouble re-setting the detent ball/spring.
turbodave
03-29-2019 07:22 AM
booper169
11-09-2010 09:10 AM
sydneysport
10-01-2006 09:18 PM
