heater
Old Dec 16, 2007 | 08:36 PM
Bulldogs_1789's Avatar
4wd High
Default heater
Ok, just hit around 20 degrees F outside and my heater desided to malfunction,(kicks on and off repeatedly) too dark to check the fuses now. Any other things I should check or head on up to LR of chattanooga?
2001 Disco2 110k
Old Dec 16, 2007 | 10:54 PM
JayhawkinIdaho's Avatar
Default RE: heater
I'm going to leave this one to Discomike, however on a Mercedes I owned with auto climate control units, if the coolant level was low, the auto system would kick the fan down for about 2 minutes, then kick it back on with heat then kick off again. Put coolant back in to the levels recommended and it functioned correctly. Have you tried the manual over ride for floor heat only? Logically if it does not stay on at all and shuts down then it will be an electrical issue, possible relay issue.
Old Dec 17, 2007 | 09:27 AM
Default RE: heater
Are you talking about the fan or the heat from the heater?
Old Dec 18, 2007 | 08:07 AM
4wd High
Default RE: heater
thanks man, you had it, coolant reserve tank was empty...had to order another one though, the old one has a leak...not too bad, it will hold till the new one arrives
Old Dec 18, 2007 | 09:51 AM
Default RE: heater
Check it daily and keep it filled to the top of the lid. You are already allowing the engine to run hotter then it should which with time will cost you big time.
Old Dec 18, 2007 | 10:05 AM
ajh's Avatar
ajh
Default RE: heater
Has anyone fitted a real overflow tank? It would be nice to be able to add coolant when hot.
ls1morethanyou
Jan 12, 2017 10:21 AM
tonygallagher
Jun 17, 2006 08:22 PM
jomeheretu11
Nov 1, 2005 05:13 PM
philipm7
Aug 27, 2005 10:12 PM
ddugan
Feb 20, 2005 02:27 AM
