Heater
Old Dec 2, 2016 | 06:40 AM
redrover75's Avatar
Default Heater
I saw the previous post and it reminded me of my issue.
I get heat from the defrost vents in the summer, less so in the winter.
My footwell vents work mostly, although not as much as i would hope.
The main vents barely have any heat.
I have bled it, i believe that is not the issue. I used to have some waterfall noise in the dash, however that is gone.
When i put it on full blast, i get lots of cold air.
When I put it on auto, there is very limited heat.
The more i think about it, the more it sounds like a heater core, but wouldn't that prevent any material heat?
Start with flushing the core?
Old Dec 3, 2016 | 10:00 AM
Bom2oo2's Avatar
Start with checking inlet and outlet hoses to heater core with engine hot, both should be hot, if outlet pipe is a lot cooler then your core is partly clogged, flush the heater core, can use a radiator flush just for heater with boiling water, let it sit in heater for a while, then flush with garden hose & then with distilled water, if it isn't completely clogged will clear it somewhat enough to get hot air again, but if really bad, you might need a new core.
ls1morethanyou
Jan 12, 2017 10:21 AM
tonygallagher
Jun 17, 2006 08:22 PM
jomeheretu11
Nov 1, 2005 05:13 PM
philipm7
Aug 27, 2005 10:12 PM
ddugan
Feb 20, 2005 02:27 AM
