Heater hose cutoff?
Old Dec 19, 2015 | 02:01 PM
Charlie_V's Avatar
Default Heater hose cutoff?
I have a Nissan Titan and it suddenly decided to stop blowing heat. My miniature wife gets cold when you open the refrigerator door in the other end of the house, so that wouldn't do. I researched a little and found that the Titan has a motorized valve right there in the engine compartment that cuts the coolant off when cold air is desired or the system is off. I messed with the little plastic thing and it started working again.
Flash back to yesterday before I charged my new compressor on the Disco. Driving down the road... warm air coming out with the system off.
So do we have a valve like that? Any reason why we can't?
Old Dec 19, 2015 | 09:16 PM
Alex_M's Avatar
I don't think we do, but I see no reason why we couldn't. That said, the only time I've ever had my vents blow hot with the system off is when I had the heat on before I turned it off. If I turn the air back on, turn the temp all the way down, and then turn it back off. Always seems to fix the issue.
Old Dec 20, 2015 | 10:51 AM
Charlie_V's Avatar
That's a good point Alex. And I do recall that when I leave it on a cool setting, no heat escapes. It is curious that it depends on the last setting... hot coolant is circulating or it isn't, right? That tells me we do have a valve but maybe ours is in the dash. I'll look into it.
Old Dec 20, 2015 | 12:01 PM
Alex_M's Avatar
Yea, best I can figure is that there's a motorized flap in the air vents, not in the coolant line as with your Titan (nice trucks by the way). Pretty much every vehicle I've ever driven has worked that way, except our Mustang which when you turn the air off there is no air bleed at all through the vents. Odd.
Old Dec 20, 2015 | 03:02 PM
Charlie_V's Avatar
I was actually thinking of your AC delete as I was driving. I wondered whether you were bathed in warm air. In Texas that's no good regardless of the time of year. I do fine with the windows down, unless it is raining. If you've seen me in any videos you know I'm not carrying much insulation around.
Old Dec 20, 2015 | 06:12 PM
Externet's Avatar
A manual shutoff may help you.
----> Heater Hose Shut-off For Summer Photo by Innernet | Photobucket
Old Dec 20, 2015 | 06:17 PM
Alex_M's Avatar
Nope, I'm not bathed in warm air unless it's a.) hot outside, or b.) I have the heat on.
I love the heat. Florida in July is the best. I'm like you, I just use Windows. Really even if it's raining I'll still leave my windows down. As long as you're moving these bricks don't really seem to drag the water into the windows. If it really comes a downpour I'll roll them up some, but still not all the way.
D2 2003
Nov 7, 2017 07:41 AM
Sam95disco
Dec 6, 2011 08:52 PM
amaxson
Jun 23, 2011 10:48 AM
Rover Rebel
Jan 1, 2011 02:55 PM
KERBY187
Nov 10, 2009 10:56 AM
