Heater pushes air even when turned off
my heater continues to push air through the vents even when the heater is turned off - what's weird is that I have no other heater problems. Blend doors operate fine, both driver and passenger temperature controls operate as they should....
'01 disco II with 62k on the clock.
Any ideas?
Any ideas?
on
Actually, yes for a D2 it did happen, Rover was aware of it and tried to modify the control unit to correct the problem thru a TSB, with no luck.
Pretty much just have to live with it.
I have found with mine that if I turn on the a/c for a couple minutes then turn it off that in mine it seems to lessen the heat level some.
aarongregor
01-16-2012 11:43 AM
40ranger
03-19-2008 05:11 PM
