Heater pushes air even when turned off
Old Oct 24, 2011 | 07:36 PM
01d2Jeff's Avatar
Default Heater pushes air even when turned off
my heater continues to push air through the vents even when the heater is turned off - what's weird is that I have no other heater problems. Blend doors operate fine, both driver and passenger temperature controls operate as they should....
'01 disco II with 62k on the clock.
Any ideas?
Old Oct 24, 2011 | 07:51 PM
cipher982's Avatar
It's just something I think happens in any car. If the setting was on heat when you turned it off the vents will still be opened to the heater core. So when you're driving the natural air movement will push some inside the cabin.
Old Oct 24, 2011 | 08:22 PM
Perfectly normal, all cars do this, if you stop the air will stop.
Old Oct 25, 2011 | 05:54 AM
drowssap's Avatar
you should turn the temp down before shutting off the heat or heat will continue to come out, for some reason the mixing doors do not close when the heat or AC are off. Just one of those land Rover things I guess; they all do it.
Old Oct 25, 2011 | 09:35 AM
Actually, yes for a D2 it did happen, Rover was aware of it and tried to modify the control unit to correct the problem thru a TSB, with no luck.
Pretty much just have to live with it.
I have found with mine that if I turn on the a/c for a couple minutes then turn it off that in mine it seems to lessen the heat level some.
aarongregor
Jan 16, 2012 11:43 AM
Miwo
May 4, 2011 08:40 AM
meltdowndave
Apr 21, 2008 07:39 PM
40ranger
Mar 19, 2008 05:11 PM
Rover82
Apr 20, 2007 07:01 PM
