Helicoil treads in block?
Old Aug 18, 2010 | 12:28 AM
00&04 Disco's Avatar
Default Helicoil treads in block?
I purchased another 2000 Disco and an rebuilding the whole top end and new water pump. When I was tightening down the heads I did the suggested 15 lbs and than mark it and 90 and than another 90. I was just starting my second tightening sequence and on the number 1 bolt I started tightening it and it was tight and than became loose. Took the head back off and noticed threads comming out of the hole. I pulled all the threads out like a helicoil was put in the block at one time. I guess my question is has anyone had to helicoil their block before and what kind of luck did you have? I am guessing I am going to have to helicoil it tomorrow and see how it goes, dont see any other way.
Old Aug 18, 2010 | 08:30 PM
vandev's Avatar
Default that sucks..
thats sucks as the bolts you already torqued are finished. you need to get new head bolts again. I would check with a machine shop first about helicoil to make sure it can take the torque. they may need to refill and tap a new hole...or worst...it's toast. Remember, the head bolts are only milimeters away from the water jackets. It it was my block and i need it refilled i would resleeve as to make sure i was not compromising the block by the refill of material and retap. Just my 2 cents.... no sence wasting all that money to fill a crack behind the liner....
let us know, Chris
humroot
Jul 22, 2019 06:33 PM
NorCalDisco
Sep 5, 2014 03:04 PM
TRIARII
Aug 1, 2014 03:07 PM
focusontheworld
Oct 9, 2012 07:11 AM
JBEGIN
Jun 27, 2009 12:38 PM
