HELLLPPP!! ECU issue
Old Nov 21, 2015 | 06:17 PM
jafir's Avatar
Originally Posted by mln01
What mileage shows on the odometer now, compared to what was shown previously?
It shouldn't have changed at all. The miles are stored in the cluster and BCU and he changed the ECM.
Old Nov 21, 2015 | 08:32 PM
mln01's Avatar
At one point the OP was going to change the BCU too. Regardless of that the cluster change only could have caused a change in the odometer.
Old Nov 22, 2015 | 10:17 AM
clint70's Avatar
min01, the mileage still stays as long as you don't change the BCU or Cluster. With the Nanocom, you can sync the mileage with the system IF there is an issue though. When I swapped I didn't have an issue, the mileage stayed with the original.
Cheers!
Old Nov 26, 2015 | 03:16 PM
toofaroffroad's Avatar
Hi CLINT70, I'm grateful and excited I've found a member near by with a nanocom. He will help in reprogramming my new (used) ECU. I was hoping you could run through the step by step on what you did.
1- disconnect battery
2- remove old ECU ??? or not?
3- ?
4- ?
5- ?
Thanks for any help. I just don't wanna waist this guys time.
Old Nov 30, 2015 | 06:27 PM
So...I went through all the steps and when I got to "learn security code" it came back saying "learn security code function terminated"???? no idea what that means. Another member also suggested disabling the immobilizer function and the truck will work. I'll try and report back.
Old Nov 6, 2019 | 02:50 AM
AussieRover111's Avatar
Need ECU BCU and IC off a junked truck. Even if the dealer can fix it will be big boo coo bucks. Thousands of dollas.
Old Nov 6, 2019 | 05:43 AM
mln01's Avatar
Uh, dude, the last post in this thread before yours was nearly 14 years ago. Are you our latest troll?
Roflcopter
Jul 19, 2021 03:06 PM
toofaroffroad
Nov 24, 2015 06:50 PM
floundering
Jul 7, 2015 04:53 PM
emt2976
Sep 4, 2014 05:49 PM
morbengan
Jun 16, 2014 05:57 AM
