Help with 2 Fault Codes
Old Feb 21, 2014 | 01:58 PM
ems12's Avatar
Default Help with 2 Fault Codes
I have
P0420 Catalyst System Efficiency Bellow Threshold Bank 1
P0441 Evaporative Emission control system incorrect purge flow.
These in reference to my O2 sensors or my catalytic converters?
I just got a new catback system so I can go ahead and get new cat's if I need to.
Is this information in the Rave manual?
Old Feb 21, 2014 | 02:15 PM
ems12's Avatar
I managed to answer my own question I think.
P0420 is the O2 sensors.
P0441 is the gas cap?
How did I do?
Old Feb 21, 2014 | 02:43 PM
SDinDS's Avatar
How did I do?
P0441 could be the gas cap. Replace it, clear the code and see if it comes back. If it does then it could be the purge control valve.
Old Feb 21, 2014 | 07:41 PM
jfall's Avatar
you did well.
i have a little lookup system
http://enginecodemaster.com
cause it is easier that way.
Old Feb 22, 2014 | 09:53 PM
ems12's Avatar
Originally Posted by jfall
you did well.
Good deal
According to the RAVE 0420 is Catalyst efficiency deteriorated - LH bank.
So is this a 02 sensor or my Left hand Catalytic converter?
Don't think it's a 02 Sensor.
06Range
May 8, 2013 09:01 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
