Help with 2 Fault Codes
I have
P0420 Catalyst System Efficiency Bellow Threshold Bank 1
P0441 Evaporative Emission control system incorrect purge flow.
These in reference to my O2 sensors or my catalytic converters?
I just got a new catback system so I can go ahead and get new cat's if I need to.
Is this information in the Rave manual?
P0441 could be the gas cap. Replace it, clear the code and see if it comes back. If it does then it could be the purge control valve.
you did well.
i have a little lookup system
http://enginecodemaster.com
cause it is easier that way.
you did well.
According to the RAVE 0420 is Catalyst efficiency deteriorated - LH bank.
So is this a 02 sensor or my Left hand Catalytic converter?
Don't think it's a 02 Sensor.
mcvayrover
Jan 8, 2024 11:50 AM
kbarker27
Oct 13, 2023 04:03 PM
06Range
May 8, 2013 09:01 PM
