Help
Old Mar 11, 2017 | 01:41 PM
thensley723's Avatar
Default Help
Trying to remove water pump. Bolts to the Lully will not loosen. I still have tension on the belt to aid me but no matter what the pulley just spins.
Old Mar 11, 2017 | 04:58 PM
PalmettoDisco's Avatar
Remove belt, remove fan, leave pulley alone, remove bolts attached to the front cover, remove coolant hose from snout, remove water pump.
Old Mar 11, 2017 | 05:39 PM
abran's Avatar
If I remember correctly, the pulley has to come off to get to all the 10mm bolts.
Either way, use a strap wrench to hold the pulley.
Old Mar 11, 2017 | 06:56 PM
Well right after posting this I got two of the bolts loose. The third one rounded. So for now I tightened the ther two back and I'm saving my water pump for another day. It was just a thing I was going to do while I was doing my head gaskets.
Old Mar 12, 2017 | 09:38 AM
abran's Avatar
Buy a set of bolt extractors and a strap wrench. Might as well tackle the job now while doing the head gaskets.
9 Pc 3/8 in. Drive Metric Bolt Extractor Socket Set
Old Mar 13, 2017 | 07:35 AM
jamestfl's Avatar
this thing is a champ...
This is the "gold" standard of stud extractors.
you can get them in 3/8 and 1/2 Drive
https://www.jbtoolsales.com/mayhew-t...FU5tfgod4wML5Q
edit* here is a cheaper link:
Bits - Neiko 3/8 Inch Drive Universal Stud Extractor 01999A
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
