Help. AC/Heater probs
Old Sep 7, 2021 | 05:13 PM
Theresonly1santi@gmail.com's Avatar
Default Help. AC/Heater probs
So my air was working fine and then one day it just stopped blowing. It’s a 2002 disco 2. Doesn’t matter if it’s on high or low it doesn’t blow when I’m driving I can feel cold air coming out as well as heat come out if I change the temperature but it doesn’t blow on the smallest setting like it should or the highest. My rear doesn’t blow either can someone help me out.
also I did a diagnostic test on the panel where you press and hold the two buttons and turn the key over at the same time and error codes 21 and 22 came up I looked it up and it says left and right sunlight sensor which I have no clue what that means or if that has anything to do with the air not blowing. So I looked to see how to fix it and people were saying your vehicle needs to be in the direct sunlight but it was sitting outside in the sun all day before I did that test so I have no idea what that means … please help I need air lol thanks, disco lover
Old Sep 7, 2021 | 05:43 PM
redwhitekat's Avatar
Fan is not coming on ?
try checking fuses
connection at motor. See if any power there
Old Sep 7, 2021 | 06:18 PM
try checking fuses
hey thanks for the reply. I forgot to mention I checked the fuses and they all looked good the interior and exterior fuses. When you say connection at motor do you mean like the plug to the fuse block
Old Sep 8, 2021 | 01:57 AM
mollusc's Avatar
Did you actually test the fuses, or just look at them? Blown fuses can often look just fine.
Old Sep 8, 2021 | 04:56 AM
Massrover's Avatar
Default Could be a couple things
In the last year I replaced the blower resistor and the blower motor. The resistor got it working for a little bit but then it stopped working when the weather got hot and the a/c cranked. I replaced the blower motor and no more issues all summer long. I know a lot but f folks say check your fuses and that’s a good cheap fix if it’s that simple. But you may need one or both of the parts I replaced also.
Old Sep 8, 2021 | 06:24 AM
yea I just pulled each fuse out to see if it was scorched or not and they weren’t but I will test them
Old Sep 8, 2021 | 06:25 AM
is there anyway to see if the blower motor is bad or is that something I just replace and hope it’s that?
Old Sep 8, 2021 | 06:40 AM
could be a number of things, you need a meter to test fuses, also need a meter to check if you have power at your fan motor, could be a resistor but usually one speed would work,
Carlos Man
Aug 26, 2019 04:19 PM
KenR
Aug 4, 2011 09:03 AM
Dream Theater
Mar 25, 2009 06:14 PM
jsyonker
Nov 1, 2007 07:22 PM
