Help with diagnosis
Old Oct 19, 2010 | 03:03 PM
peanuts8888's Avatar
Default Help with diagnosis
Recently I've notice a knock or grinding noise that seems to come from underneath the center console when decelerating or cruising at 30-35 mph. I'm assuming that it's coming from the transmission. I've had the truck almost a month. It has all the service records up to 90K which was completed in Aug 09. The truck now has 113K. I plan to check/change the trans fluid and filter. Are there any diagnosis or other maintenance services that I should complete? Thanks
Old Oct 19, 2010 | 03:04 PM
ROVERTECH15's Avatar
Check the front drive shaft
Old Oct 19, 2010 | 03:21 PM
hilltoppersx's Avatar
agreed, stop driving it. you need to climb under the truck and see if the front drive shaft has been rebuilt with greasable u joints. if not you need to get it rebuilt at a local drive line shop or replaced with a new one from Tom woods or Great Basin Rovers.
Old Oct 19, 2010 | 04:50 PM
I already had the drive shaft rebuilt. Any other diagnoses?
Old Oct 19, 2010 | 04:58 PM
Long Haul's Avatar
I would check the output shafts on the transfercase for play. Might be a bad out put shaft bearing.
Old Oct 19, 2010 | 05:00 PM
could be drive line slack as well.
Old Oct 20, 2010 | 09:40 AM
Remove the front drive shaft, engage the CDL and drive on the rear shaft only to see if the noise goes away.
Old Oct 20, 2010 | 10:48 AM
Ok, stay tuned.
Old Oct 20, 2010 | 02:02 PM
cptshanman's Avatar
Yes, agree with Mike and others...
Please do not drive until you try Mike's remedy. That sound is EXACTLY what my front drive shaft sounded like within 10 minutes of it busting on my truck. Very very bad news if it goes while driving...
Shannon
DiscoRover007
Jul 7, 2015 04:47 PM
Tommy9999
Apr 14, 2011 12:28 PM
jycsalas
Dec 4, 2010 11:16 AM
hag1128
Feb 6, 2009 10:03 AM
Phototone
Jun 14, 2008 08:20 AM
