HELP has anyone seen this before
You need to have the codes read with a Land Rover specific computer.
ECUs can go bad, but not 100% common.
trans ECU is under one of the seats. Have you had any water get inside? The D with the slash makes me think the trans ECU. Again, one big guess without reading the codes.
Anyone know how to fix this
It will clear it but pops right back I just was hoping there was a trick to resetting the anti theft module itself I'm in Nc
Where are you from in North Carolina? I'm in Boone.
As for your issue, the last time I ran into trouble with the anti theft system the car immobilized itself. No lights lit up and the car seemed dead. I disconnected the battery and let it sit for ~6 hours then reconnected the battery and it fired right up. No clue why, electronics can be weird sometimes. This probably won't work in your situation but I'd give it a shot.
PS: I have a hawkeye scanner tool for land rovers. If you are close I'd be fine with letting you borrow it if it's helpful.
