Help Interpreting Codes
Old Apr 21, 2009 | 10:46 PM
roverguy7's Avatar
what o2s did you replace? if you didnt do the upstream also on bank 1, id start there and see if it goes away
Old Apr 22, 2009 | 08:35 AM
AK Rover's Avatar
I replaced the rear O2 on each side. I didn't have codes from any sensor except the passenger side downstream. I don't have money to buy a sensor right now, especially if I don't know for sure that it will fix the problem.
Old Apr 22, 2009 | 08:23 PM
roverguy7's Avatar
the you need to know for sure... this code is stored when the ecu sees the down stream switching at near the rate of the upstream9it should switch a good amount slower, ie working catalyst) so, either your cat isnt doing what it should, or your upstream is switching slow, sometimes they dont throw the codes that they should. best ways to check are your o2 sensor voltages and your cat temperature. if you have a infered thermometer, check yours cats, right before, and right after them. should be hotter post cat.
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
twaszak
Nov 30, 2010 08:06 PM
BajaXJ92
Dec 3, 2009 07:43 PM
