Help loosening transfer case fill plug
Old Jun 12, 2017 | 05:06 PM
huggi's Avatar
Default Help loosening transfer case fill plug
I tried a wobble extension, universal joint....also bought a low profile 1/2 drive socket that didn't fit under the e brake cable. Soaked it in pb blaster.
Any other suggestions?
Old Jun 12, 2017 | 05:18 PM
disc oh no's Avatar
Try heat. Sometimes they put loctite on those.
Old Jun 12, 2017 | 05:49 PM
OffroadFrance's Avatar
Use a 125 or 150mm short 1/2" extension on a 60 or 90cm breaker bar as they are often loctited in place. They are a tapered thread and can be very tight to free up. Use a smear of RTV on the threads only when refitting the screw plug.
Old Jun 13, 2017 | 03:20 AM
The Deputy's Avatar
They say prayer can be a powerful thing, but I've found that swearing at it helps more.
Why they didn't completely bury it behind the brake drum l'll never know...maybe LR just wanted to give us a false sense of hope...lol.
But, seriously...I just drove a 3 inch extension into the plug with a hammer and then added a breaker bar to that and then added a pipe to that...and then...what seemed like moments before the rover rolled over on its side and my ***** blew out of their sack...the plug broke loose.
Brian.
Old Jun 13, 2017 | 06:26 AM
Originally Posted by the deputy
they say prayer can be a powerful thing, but i've found that swearing at it helps more.
Why they didn't completely bury it behind the brake drum l'll never know...maybe lr just wanted to give us a false sense of hope...lol.
Brian.
:d:d
Old Jun 13, 2017 | 08:44 AM
mln01's Avatar
I did not need this image.
Old Jun 13, 2017 | 11:38 AM
Mskembo's Avatar
Now I know why I'm scared to do anything with the TC.
Old Jun 13, 2017 | 12:59 PM
huggi's Avatar
Lol thanks for the visual Brian. So you were able to get a regular extension in there? Mine has to go in at a pretty sharp angle hence the universal joint or wobble extension.
My ***** were firmly planted in my sack, so I clearly didn't push hard enough
Grumpo
Oct 22, 2012 12:22 PM
Disconoobie
Oct 19, 2010 07:36 AM
Disco Alan
Apr 21, 2009 06:22 PM
jrkstore43
Mar 2, 2009 08:27 AM
Phototone
Apr 7, 2008 03:59 PM
