Help!! Loud ticking!! Weird
Old Dec 13, 2011 | 06:27 PM
Well, that's noise, but perhaps you could narrow it down a little more. This could be something besides the oil pump.
In addition to searching for the noise with a stethoscope (parts store) or a listening stick, you could test each pulley or item that turns.
1. Remove the serpantine belt. That physically disconnects all the devices.
2. Crank truck. If noise is gone, it is one of the pulleys or idler wheels or devices that rotate.
3. If noise is still there, all the things run by belt have been eliminated and it is time to do oil pump test. Noise could be valve train and lifter running on low oil pressure.
4. If noise is not there when cranked without belt, turn off truck. Turn each thing that rotates by hand, listening and feeling for any roughness. Could be alternator bearing, water pump bearing, air conditioning compressor clutch, idler pulleys, power steering pump bearing.
If can't be sure of a noise maker, re-attach belt, paying attention to the route. See route in link below.
With belt back on, triple check route. Crank truck, if noise returns check things with a stethoscope or listening stick.
How about posting your results?
File Type: pdf
Old Dec 13, 2011 | 07:58 PM
SolbergFanBoi's Avatar
Originally Posted by trp34
try letting the engine cool and remover your belt. This will remove any of the accessory drive components from the equasion.
Originally Posted by savannah buzz
well, that's noise, but perhaps you could narrow it down a little more. This could be something besides the oil pump.
+1111111
Old Dec 13, 2011 | 08:14 PM
Engine noises are like music, people hear things differently, especially when there is a symphony...
Old Dec 14, 2011 | 08:52 AM
p4nth4's Avatar
ok, will do. thanx again guys for all the helpul ideas and yes, i will post resulte shortly.
lrjon
Nov 23, 2019 06:00 AM
sloan74
May 12, 2011 10:11 PM
2003DICSO
Aug 7, 2009 06:13 PM
DiscOklahoma
Jun 10, 2008 05:33 PM
rovergirl79
Aug 4, 2005 02:19 PM
