Help me with 2 things (pics)
Old Feb 11, 2013 | 02:06 PM
mtrdrms's Avatar
Default Help me with 2 things (pics)
I recently decided to pull my heads after investigating a low compression situation on number 6. It turns out the headgasket blew through on the intake manifold side not a valve like I suspected.
So I am mid headgasket job and I found this little metal ring in the valley after I pulled the right cylinder head. Any idea what it is? If was just laying against a lifter.
Secondly there is a dark spot on the number seven liner right next to the coolant jacket. Should I be worried?
Thanks!
Andy
Attached Thumbnails Help me with 2 things (pics)-disco2.jpg   Help me with 2 things (pics)-disco1.jpg
Old Feb 11, 2013 | 02:29 PM
The ring may well be an insert in the valve cover gasket that keeps you from smashing the gasket when you torque down those 8mm 12 points.
Old Feb 11, 2013 | 02:46 PM
mtrdrms's Avatar
Great call savannah! That's totally what it is.
Old Feb 11, 2013 | 03:03 PM
jhill15's Avatar
Thanks!
Andy
Does low compression mean that you were having a misfire on 6 and code p0306?
Man I'm so paranoid about blowing my h.g. now. Like everytime something goes wrong I'm like god please don't let it be the h.g. lol.
Old Feb 11, 2013 | 03:15 PM
mtrdrms's Avatar
Exactly. 0300 and 0306. A compression test revealed abou 50psi in #6. No coolant loss and good fuel to that cylinder. So I pulled the head and sure enough the gasket was blown right thru on 6.
Old Feb 11, 2013 | 03:17 PM
mtrdrms's Avatar
It's really not that hard to do if your handy. Get the Atlantic British kit - very complete.
Old Feb 11, 2013 | 03:23 PM
jhill15's Avatar
That is exactly what mine is 0300 and 0306. I just started a thread last night on it. I'm about to change my plugs and wires cause I have cheap single platinum and really old wires and I was hoping that replacing them with Bosch double plus 4 and magnecor 7mm would fix it. But knowing that you have the exact same codes I may not even waist my $ $350 after shop time and parts.
Was your truck kinda sputtering on take off and misfiring at idle?
Old Feb 11, 2013 | 03:28 PM
mtrdrms's Avatar
It would pull ok but the idle got rough. It was easy to tell something was up. You can swap the #6 plug with another and see if the misfire follows it. Can you run a compression test? That will tell you a lot.
Old Feb 11, 2013 | 03:39 PM
jhill15's Avatar
thehun
Mar 7, 2013 01:35 AM
Young
Nov 17, 2009 04:09 PM
sarahgibbons5
Apr 22, 2009 12:37 AM
Brad S1
Jul 7, 2006 10:26 AM
Off Topic
Apr 28, 2005 04:02 AM
