Help with codes please
Old Feb 28, 2013 | 04:51 PM
invalidusername's Avatar
Default Help with codes please
Ok I drove through a big muddy area yesterday and hit a few puddles, nothing a disco can't handle right?
A bit afterwards I felt the car shudder at idle without RPM gauge fluctuating
Got home a few miles away and all seemed well. I drove to work this morning and found the service engine soon light on.
Checked codes after work at autozone I got
P0152 - o2 sensor?
then P0301 and P0305
Anything to do with the puddle? What should I do?
Drives fine like nothing is wrong except with a random shudder here and there at idle
Old Feb 28, 2013 | 05:12 PM
What color are your plug wires, if grey, they are junk and and would cause the 2 mis-fires. You need 8 mm silicone wire that won't leak when wet throwing codes. as for the 152 code, bank 2 sensor one is gone and you should replace both front's to get your air/fuel ration equal on both banks.
Old Feb 28, 2013 | 05:44 PM
I have yellow ones they were recently replaced. During a top end rebuild for headgasket
I forget where and what they are called. Kings something? I believe they were 8mm
Is bank 2 on the passenger side?
Is it at the bottom?
If it dries out should it be fine?
Old Feb 28, 2013 | 06:08 PM
Only time will tell.
Old Feb 28, 2013 | 11:31 PM
jfall's Avatar
Looks like you got misfire codes.
You can plug codes into this site:
http://enginecodemaster.com
It has most of the codes from the RAVE in it by now.
Old Mar 1, 2013 | 12:26 AM
robdis96's Avatar
I had issues with getting some O2 codes, and I replaced them one by one only to have the next one go. I replaced them all and haven't had an issue since. Best to do em in pairs at least IMO
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
