help me guys
Old Apr 23, 2020 | 05:55 PM
Giorgier's Avatar
Default help me guys
on my disco 2 EGR secondary air injection is disabled and check engine light is allways on how i can just shut off disable this light and never come back light is allways on and dont tell me anything thank you guys (sorry for my language)
Old Apr 23, 2020 | 05:59 PM
Jason_B's Avatar
You can disable the check engine light by removing the bulb or snipping the wire. What is the point though?
How is the SAI disabled? Did you remove it?
Old Apr 23, 2020 | 06:11 PM
Giorgier's Avatar
when i buy SAI was already disabled by mechanic how i can disable wire? just cut it? where is this wire?
Giorgier's Avatar
car has no any problems working perfectly
Old Apr 23, 2020 | 06:25 PM
Extinct's Avatar
You can flash the ECU with non-SAI engine code and it will go out.
Old Apr 23, 2020 | 06:31 PM
Giorgier's Avatar
how can i do this ??
Old Apr 23, 2020 | 08:31 PM
mollusc's Avatar
Don't disable the light. You won't know if some other issue comes up.
You might be able to change the settings if you can find someone who has a high-end OBD-II tool. Like a mechanic who has a professional device.
Old Apr 23, 2020 | 08:36 PM
Giorgier's Avatar
thank you i decided change ecm with non sai ecm
Old Apr 23, 2020 | 11:21 PM
redwhitekat's Avatar
did it work
csn4646
Aug 12, 2009 01:16 PM
wolfie
Jul 2, 2009 05:18 PM
greenlander
Oct 29, 2008 02:13 PM
hsipromo
Sep 16, 2008 08:29 PM
christians1600
Jun 27, 2008 06:56 AM
