Help MisFire Question! Thanks
Old May 3, 2011 | 08:54 PM
MTristan's Avatar
Default Help MisFire Question! Thanks
Hello Eveyone, My 2000 Discovery "Service Check Engine" Light Came On, Took It to Autozone To Read The Codes I Got this Codes:
P0308
p0300
p1300
The Truck Runs Great,and Everything.The Auto Zone told me it was a Misfire Problem. What should I Change? What Brand Wires,Spark Plugs Should I Use? Thanks Everyone So Much Ya Are All Always a Huge Help!
Old May 3, 2011 | 09:19 PM
Champion cooper spark plugs, Kingsbourne or Magnecore plug wires.
Read the write up section for the "how to" on how to do a tune up on your truck.
Old May 3, 2011 | 09:46 PM
MTristan's Avatar
Thank You So Much Spike555, Your Always A Big Help,Really Appreciate it! The Auto Zone guy said it could be the "Ignition Coil" what do you think? About 2, Days ago I went to turn on My truck and it turned on But The a/c, and The Radio Didn't, I Turned it off. Then Turned it Back on and It Wouldn't Start. After About 5 Minutes I Tried it again and Everything came on Great. Hadn't Had a Problem and Everything seems to run Great.Any idea if it could be due to the codes that came up? Thanks So Much!!!
Old May 4, 2011 | 07:26 AM
Bundu's Avatar
Banned
When doing repairs you start replacing the cheapest parts first and work your way up to the expensive bits, they would be in this order: spark plugs, plugs wires, coil packs.
Replace your spark plugs and plug wires and see how that goes before you even consider the expensive coil packs.
I used Champion 318 plugs at about $2 each and kingsborne 8mm wires at about $60. Kingsborne Wire Werks Inc - Spark plug wires, Automotive, RV, Motorcycle, Marine, Racing, Industry
Old May 4, 2011 | 12:05 PM
MTristan's Avatar
Thank You So Much Will Do That! I Am Very Greatful For this Forums! All of you always Help Alot!!! Thank You!
Gromeo
Jan 24, 2013 03:41 PM
lipadj46
Jun 11, 2009 01:30 PM
ek5usmc
Oct 12, 2008 03:03 AM
i_m_jon
Mar 16, 2007 09:42 PM
JVG1999
Mar 11, 2006 06:34 AM
