Help my Discovery is stalling
Old Jun 16, 2005 | 02:27 AM
MikeRover's Avatar
Default Help my Discovery is stalling
Hello,
I'm new to these forums. And I found them as I am trying to find out what is wrong with my Disco.
I have a 98 Discovery 5speed manual. And it occasionaly would stall as I would come up to a rolling stop while on neutral. As it would start again immediately and would not repeat this problem for some while I hadn't been to worried about it.
The other day it stalled on me again but this time it refused to start. The starter was cranking perfectly, so I don't think it was an electrical problem. About an hour later is started just fine and it has kept on starting just fine. I'm going to change the spark plugs just as a precaution but I'm worried that it might not be the cause. I'm wondering if might be the fuel pump.
Has anyone experience this problem before and better still managed to resolve it.
Thanks
Old Jun 16, 2005 | 12:41 PM
im so scene's Avatar
7th Gear
Default RE: Help my Discovery is stalling
check fuel pump/rail pressure. maybe clogged filter or clogged line. it definitly sounds like a fuel related problem
Old Jun 16, 2005 | 01:49 PM
mikemeyer0's Avatar
turn key on and listen to see if there is sound coming frome the gas tank. if there is then fuel pump could be ok, you may have to check this when it stalls again. If it is fuel pump get back with me, i have a tip to save you a couple hundred bucks.
Old Jun 16, 2005 | 05:55 PM
MikeRover's Avatar
Thanks Mike,
If got the local garage changing the plugs and checking around. I'm almost positive they won't find anything but I will tell them to clean out the fuel filter anyway.
As to what you said about the fuel pump, I do remember thinking that as I was cranking pretty hard, I was not getting that distinct fuel smell I would have been expecting. Which brings up another point: Lucas Electronics [:@]. So it may turn out to be something like that.
What is it about the Fuel Pump as I probably will want to do it anyway.
Thanks
Mike
Old Jun 16, 2005 | 06:06 PM
mikemeyer0's Avatar
they will need to put in a new one, not clean it out.
As to what you said about the fuel pump, I do remember thinking that as I was cranking pretty hard, I was not getting that distinct fuel smell I would have been expecting. Which brings up another point: Lucas Electronics . So it may turn out to be something like that.
shouldent even have a fuel smell, maybe a leak if you did and that could be your prob.
also fuel pump on yours would not be lucas elec., but AC Delco.
I have a part # to get it from autozone to where you replace just the pump and not the whole assembly. $80 part vs. $300 part.
Old Jun 16, 2005 | 06:21 PM
MikeRover's Avatar
OK have them replace the filter.
By Lucas Elec. I meant the electrics conecting the pump.
The part number wont work as I'm not in US. Noted though, get pump and not complete assembly.
Old Jun 16, 2005 | 06:31 PM
mikemeyer0's Avatar
glad i could help a bit
but it is prolly the pump thats bad vs. wiring to the pump, although it still could be.
you might be able to cross refrance it.
Old Jun 25, 2005 | 04:34 PM
MikeRover's Avatar
Happy to say that after replacing the plugs and the fuel filter and the air filter the problem disapeared.
bmonkey4201
Jul 8, 2010 08:00 PM
ruggles
Jun 2, 2010 07:41 PM
bgarvertn
May 15, 2010 11:48 AM
DISCOVERY182
May 12, 2009 11:40 AM
Rover5150
Nov 28, 2007 09:57 AM
