help needed! Lug nut removal
In the junkyard the car is lifted, so when I try to remove the lug nut, the wheel starts rotating instead of the nut..
Is there a way to remove them without spending $350+ on a impact gun?
Thanks.
Thanks.
If you're just after the lugs use something thru the rim to the frame tail to stop it from spinning.
Thanks.
Thanks.
I'll see what i can do.
I got another question;
is there a point in taking hazy oxidized headlights? I came across a video where the guy ChrisFix recommends sanding them down and then applying the plastic clear coat..does it work?
