Has anyone used a Long wire type ABS Sensor ?
Once I cut it can't put back together.
Thanks for your advice
Have you tested and confirmed it is the speed sensor and not a failing hub? I would do that then go for a sensor if needed. As the which to use, doesn't make a lot of difference as long as you keep the connection clean and use some dye electric, you will not have any issue with the original short wire version.
Gavster
03-07-2009 03:44 PM
