Help!!! Odd squeaking noise
Old Sep 20, 2007 | 09:04 PM
starcraft's Avatar
Default Help!!! Odd squeaking noise
Hey guys I was driving home this afternoon and my truck started to squeak. The sound is much like the sound you get from a broken muffler bracket (it isnt constant, its more like a vibration sound), however it only happens when I am accelerating. I did a test and put the truck in nuetral and gave it some gas..........no sound at all. Can anyone help me with troubleshooting. Thanks in advance.
Brett
Old Sep 20, 2007 | 09:23 PM
geotrash's Avatar
Default RE: Help!!! Odd squeaking noise
Crawl under it and start shaking stuff.
Old Sep 21, 2007 | 08:26 AM
If it is s D2, then check your front drive shaft, if the two u-joints that are in the constant velocity houing don't have grease fitting, you probably found your problem. If that is the case, don't drive it any more cause it will fail and a possible $7000 repair cost, well I shouldn't have to say any more.
Get back to me and I'll give you some repair options.
Old Sep 25, 2007 | 02:41 PM
starcraft's Avatar
Sorry for the delay in replying,I have been out of town for the past couple of days. I am not sure what to be looking for under the truck (I am by no means a mechanic).Is there anysite that I can go to findpictures of what you are talking about discomike? Or, by the same token,what part of the car should I take a picture ofso that I can post it for you to take a look at. One other thing to mention about the noise is that it is not always there. Actually, the truck ismore often quiet. Regardless, I am going to letit sit till I find out more ...... the7000 jobhas got me spooked. Please get back to me.
Brett
Old Sep 25, 2007 | 02:45 PM
starcraft's Avatar
Ohh and the truck is a 1999 discovery 2 with 121,000 miles on it. Thanks in advance
Old Sep 25, 2007 | 03:06 PM
I would suggest either you call me or send me your number and I'll call you and walk you thru this.
303-862-7680
Colorado between 7 am and 8 pm
Old Sep 25, 2007 | 03:43 PM
starcraft's Avatar
That would be great if you dont mind me calling you. I will try to call you tonight after work if I dont get back too late (I live in NJ so I'll run out of sunlight by 4 your time). Otherwise tomorrow morning if thats ok with you. I really appreciate it.
Brett
jv3x3
Apr 9, 2022 12:12 PM
G4-Rover
Nov 29, 2011 04:51 PM
robbie1400
Mar 26, 2008 03:56 AM
robbie1400
Freelander
Mar 25, 2008 09:38 AM
sna77
Feb 9, 2007 08:00 PM
