Help!! Oil is green like the Grinch
Old Dec 26, 2017 | 06:38 PM
Mr. Tick's Avatar
Remove the oil fill cap and tell us what you see under it. And also look down the oil fill neck with a flashlight. Anything lite green there?
AR asked about oil leak dye, what about any Oil Stop Leak/or Oil Additive?
here you go Over Rover and the oil on the dipstick by the way, is before I changed the oil and I've never really seen yellow gunk under an oil cap that's a little unnerving. But im gunna Yuck
glue this baby together somehow
Old Dec 26, 2017 | 07:24 PM
Red5's Avatar
Is that the actual oil level on the dipstick??
Old Dec 26, 2017 | 07:29 PM
Mr. Tick's Avatar
hahaha no way dude! Im **** about my levels. I took it out when engine was hot & running
Old Dec 28, 2017 | 08:26 AM
shanechevelle's Avatar
This may sound gross...but after you run your truck awhile, put some miles on that oil, before you change it, take a drop from the dipstick, put it on your finger and taste it, if there is antifreeze in your oil it will be easy to tell. Antifreeze is sweet, oil is not. Sometimes, its bad enough you can smell the antifreeze.
Rinse out your tongue with some water afterwards.
cobbcj7
Dec 29, 2018 07:40 AM
Roverrocks
Jan 1, 2014 11:45 PM
mouzetangkilla28
Sep 7, 2012 08:33 PM
Disco Den
Dec 4, 2010 09:42 PM
SDinDS
Off Topic
Sep 3, 2010 04:40 PM
