Help with an oil sump bolt
Old Apr 29, 2016 | 09:49 PM
adolfojbonilla's Avatar
Default Help with an oil sump bolt
Hi Guys!
I just figured out that my mechanic forgot, misplaced or lost a bolt when replacing the gasket, now I need help in securing a replacement bolt; does anyone know the specs for it?
Please see the pic attached, thanks in advance! ;-]#
Old Apr 29, 2016 | 10:50 PM
Charlie_V's Avatar
Originally Posted by adolfojbonilla
Hi Guys!
I've got three engines and none of them have a bolt there.
Old Apr 29, 2016 | 10:57 PM
...mine is the Bosch engine and as you may see, there was a bolt; now there isn't and those pipes are quite loose.
Old Apr 29, 2016 | 11:09 PM
Charlie_V's Avatar
Mine are Bosch too, but I must have a different bracket. All three oil pans I have are threaded but didn't come with a bolt.
Now I'm wondering whether I am missing something!
Old Apr 29, 2016 | 11:17 PM
What's bothering me is that I have pics with the bolt, and now without, I think I should go pay a visit to my sloppy mechanic! ;-]#
Old May 1, 2016 | 05:23 PM
rankar's Avatar
can't you get a tap and die set and see what threads it? it doesn't seem to be a bolt requiring high tensile strength.
Old May 2, 2016 | 01:47 AM
chubbs878's Avatar
Take out the 10mm bolt that secures the heater pipes to the side of the engine block or top of the intake manifold and see if that fits. If not find you an 8mm from one of the other parts on the engine like SAI valve. It will probably be either one of those. Then you can take it up to ACE hardware and buy yourself a half-dozen.
Old May 2, 2016 | 11:31 AM
Charlie_V's Avatar
I'd love to see how this is resolved because I have nothing holding the pipes to my engine. They have brackets holding them to each other and I see that holding them to the engine is the way to go. My mechanic is an idiot and may had misplaced them, then forgot that they were ever there. But he doesn't throw anything away, ever, so if he had a picture he could probably find them.
I'm the mechanic.
tito5590805
Apr 28, 2020 12:53 AM
powderhound
Apr 11, 2015 11:40 PM
zski128
Jan 12, 2015 03:01 PM
knightmetro
Jun 10, 2014 02:49 PM
mike111
Jun 2, 2014 08:58 AM
