help only goes in reverse, M and S light flashing
Old Dec 21, 2012 | 02:53 PM
firefihter23's Avatar
k checked the atf a little low so toped it off. looks kinda brown so probaly need a flush but still nothing different. had battery tested and it is showing about 12.4 volts which is kinda low so i hooked my buddies battery up and still nothing. any ideas. could it be that my atf filter is clogged?
Old Dec 21, 2012 | 07:32 PM
Usually, when a ATF fluid is brown, and perhaps smells like burned coffee pot left on the stove; it is the clutch discs particles in suspension. And you won't be moving forward without a rebuild. Time for an indy tranny shop to look at it; or if you have slavage yards nearby, a used one. Keep in mind most Discos in the boneyard are there because of blown engine.
hallfleming
Sep 5, 2024 07:35 PM
rreinholt
Oct 10, 2013 08:47 AM
99discoIIforsale
Apr 29, 2013 09:57 AM
marlymarl
Apr 21, 2012 12:49 PM
elboy0712
Feb 7, 2010 02:42 PM
