Help with part Id on broken transmission mount. 2001 disco
Old Aug 17, 2019 | 12:46 PM
DodyDisco's Avatar
Default Help with part Id on broken transmission mount. 2001 disco
My 2001 discovery has a broken mount/bracket for transmission. Well its definitely broken but i am having a hard time finding the correct part id to order.
If i understand there is only 1 mount for the transmission?
Seems as it should be easier to find for me.
The motor mounts are intact but i will be replacing them anyway after reading around the site here it seems to be the general consensus.
It seems the bracket the mount goes to is broken and i cant find the part.
Ive had it a whopping 2 days now and am going through the sticky maintenance list. Amassing fluids etc to knock it all out.
If anyone can help with a part id for this it would be amazing.
Ill get on about the 5 trouble codes ive got going a bit later I suppose.
Old Aug 17, 2019 | 05:41 PM
Best4x4's Avatar
That is a little heat shield basically. The Mount itself is up inside of that. I've seen plenty without that little shield installed.
Old Aug 17, 2019 | 06:03 PM
DodyDisco's Avatar
Wow. I feel smart. I thought the mount had collapsed the bracket it sat on.
I was trying to look through the rave manual but i think the version i got is missing much of it.
Now i can move on to the trouble codes and front driveshaft.
Thanks a bunch.
Old Aug 17, 2019 | 07:43 PM
Best4x4's Avatar
Just watch out for that 7 mile downhill stretch! I’ve heard it’s a nightmare with a LR.
acg
Apr 26, 2019 11:26 AM
zuke
Nov 4, 2018 05:52 PM
rmuller
May 8, 2016 05:13 PM
yloDiscoII
ROAMING WITH FRIENDS
27
Aug 21, 2010 07:18 AM
igriego
Oct 20, 2008 04:40 PM
