help please
Old May 10, 2010 | 10:57 AM
  #21
xhevi's Avatar
Is there any chance of engine seizing while doing induction cleaning?
Took it to a mech (atlantic british certified if that mean anything).
but the guy very knowlgeable on LR s. Seemed very reliable.
He will check it out and give me a call.
For the engine to sezewould ir rev really high first?
Mine did not.
He did confirm that its a burned wire smell.
Will se what the damag is
Old May 10, 2010 | 09:35 PM
  #22
oysterhead's Avatar
any update? i'd like to hear what happened.
Old May 11, 2010 | 06:31 AM
  #23
xhevi's Avatar
It was the starter that was fried.
It was smoking so bad when he started up that He had to suck out all the seafoam duing poper induction cleaning runs a lot smother now. Was still smoking when I drove it home.
Qutie an expensive induction cleaning.
Great mechaninc thou. from now on taking it to him only.
Old May 17, 2010 | 12:13 PM
  #24
xhevi's Avatar
here is what went wrong....
first: i used a 1/4 tube (thinking it was a better fit for the nipple) BAD choise..
you would need a little room for air to go into the engine together with the seafoam.
second, it sucked in almost half a can of seafoam and that made the engine stall.
third, then i restarted the engine it was the starter that was keeping it run, and thats what killed it...
this morning as i was starting up the car i noticed that there was no power to the windows and imediately tired to shut it off and noticed that the key was stuck on III position, not so good for the starter,
could it be possible that the key might get stuck on the III position??
strange, but definately what can kill a starter and it did cost me quite a bit.
Old May 17, 2010 | 01:09 PM
  #25
The key could get stuck in the III position, but it is more likely that the starter is not kicking off when you release the key.
Old May 17, 2010 | 05:05 PM
  #26
discoklein's Avatar
Sorry for chiming in but as far as I can tell, these 03's and 04's are nothing but pure trash... i have replaced a front cover/oil pump, FR window motor, FR window regulator and FL window regulator, a Lower Intake Manifold Gasket... My 01 has 103K on her and runs wonderful...
Paul Aspen
Nov 4, 2013 02:10 PM
tarpon66
Jul 27, 2011 12:38 PM
sawadeh
Jul 2, 2011 08:10 PM
Speed racer
Oct 11, 2008 10:56 PM
