Help with Power Steering
I recently had to change the steering box on my disco II. After installing the rebuilt box and bleeding the system, it has boost when the steering wheel is turned to the left but none when it is turned to the right. I have bled the system over and over but no change. Any thoughts ?
Sounds like the torsion valve tube (not sure what the actual name for that is) inside the box is clogged or has bad seals.
Second option, would be a clogged feed line to the piston.
