Steering wheel/box
Old Jul 19, 2013 | 09:14 PM
R32's Avatar
R32
Default Steering wheel/box
Hi all
I'm currently experiencing a steering wheel where by turning the steering wheel is not a smooth it got stiffy during the turn this happened after a change of water pump. What could it be, i've changed the steering box (secondhand) and it was fine for one day and the problem occurs again. Do I need to bleed the power steering pipes?
Old Jul 20, 2013 | 05:43 AM
R32's Avatar
R32
Well I bleed the power steering pipes and still the same so power steering pump next. Any know where I could get one cheap pls for 2003 V8 model would td5 fit or even 3000tdi?
Old Jul 20, 2013 | 07:40 AM
Possible loose belt or failing p/s pump. If there is no foam in the reservor then you most likely got all the air out of the system.
Old Aug 8, 2013 | 08:44 AM
R32's Avatar
R32
Changed the new steering pump still stiff so look at u joint and one of them IS the problem so soaked it in oil and refitted and the stiffness gone just like that. Ordered new u joints hope to gets and replaced them together with the rear rubber prop shaft soon...
Old Aug 8, 2013 | 10:14 AM
You are saying that you replaced the front u-joints and your steering is now fixed? Doesn't make any since. If that is what you did, did you also replace your centering ball, if not, you will need to go back and replace it before it does fail.
Old Aug 8, 2013 | 12:08 PM
acamato's Avatar
I think he is referring to the u-joint on the shaft form the steering wheel to the steering box.
johnkbl
Sep 21, 2023 06:17 AM
texci77
Jun 6, 2012 01:24 PM
DiscoBritney
Dec 19, 2011 06:24 PM
losinov
Mar 21, 2011 08:57 PM
The Image
Jan 5, 2008 05:43 PM
