HELP! Power Steering Noises!
Old Nov 20, 2013 | 04:46 AM
MisterG's Avatar
Default HELP! Power Steering Noises!
Hey, I know there are plenty of threads on power steering problems but I've yet to find one that applied to my symptoms.
My 2002 LR Disco II SE has a couple issues.
Narrowed down to Power Steering System.
-When I start it up no noises come up...its not until I drive a 1/4 mile or until I make a couple of hard turns.
-The noise directly influenced by my RPMs at any time along with steering left or right.
-Noise sounds like the same noise as if it was running low on Power Steering Fluid.
-Have had a minor power steering leak for about 2 weeks now but just recently got around to fixing it.
-I siphoned out all old fluid in reservoir and replaced with Valvoline Power Steering Fluid
-Leak looks like it might be coming from bottom of pump where reservoir hose connects.
-When engine is running the reservoir doesn't bubble or aerate but rather churns inside.
-Power steering fluid levels are full and have been kept in check since first sign of leak.
-Really picked up in intensity in noise the colder it got.
-Power Steering still works great as I'm having no difficulty turning the wheel whatsoever, just hella noisy.
I'd appreciate any help I can get!
I'm just between a rock and a hard place...don't know if a new pump is in order, or if I need new hoses or what.
Thanks for any help.
-MrG
Old Nov 21, 2013 | 02:21 AM
MisterG's Avatar
UPDATE: Just did a long haul and I did notice bubbles all throughout reservoir. I suspect the leak is allowing air in...Just don't know where from! On to investigate!
notaguru2
Feb 22, 2009 05:33 PM
askewm
Dec 23, 2006 11:03 PM
Desertdualsport
Oct 26, 2006 01:12 AM
spiderfreak80
Mar 16, 2006 03:19 AM
