HELP! Starting issue stumper 1997
Old Aug 17, 2007 | 07:06 PM
rravenn13's Avatar
Default HELP! Starting issue stumper 1997
OK this is very very strange, please hear me out. My disco has had a random starting problem where it will not start and I have replaced the fuel filter and the fuel pump relay I thought everything was cool but it just started doing it again. Here is were it gets strange I was trying to check to see that the fuel pump was working. When I open the back door it starts! then I shut the back door and it wont! Open it again and it starts! Any ideas would be great!
Thanks!
Old Aug 17, 2007 | 08:09 PM
Default RE: HELP! Starting issue stumper 1997
The fuel pump will only run for just under 5 seconds when you turn the key. If the engine isn't actually running the fuel pump won't run.
Old Aug 17, 2007 | 11:03 PM
rravenn13's Avatar
Default RE: HELP! Starting issue stumper 1996
OK my theory has been tested all night! No joke it will not start unless i open the rear door! And then when I shut it it might start fine for a few more tries.
Old Aug 18, 2007 | 07:07 AM
Landzu's Avatar
Check ground wires.
Old Aug 18, 2007 | 10:04 PM
rravenn13's Avatar
Can someone please direct me to the location of the ground wires?
cheqbay1997
May 11, 2014 12:03 PM
cheqbay1997
May 6, 2014 10:09 AM
cheqbay1997
Sep 6, 2012 11:39 PM
bowser881
Dec 17, 2009 01:19 PM
Someszy
Dec 12, 2008 10:16 AM
