Help transmission is locked out
Old Aug 4, 2008 | 11:56 AM
clout98 disco's Avatar
3rd Gear
Default Help transmission is locked out
I can't disengage the automatic transmission into drive. It seems to be locked out in Park. I need some help please.....thanks
Old Aug 4, 2008 | 12:06 PM
3rd Gear
Default RE: Help transmission is locked out
This is a 1998 Disco and I just checked and I do NOT have brake lights...........any help would be greatly appreciated
Disco2Guy's Avatar
Might be your brake switch.
Old Aug 4, 2008 | 03:55 PM
Mostb likely your brake light switch is bad. I have not done this but somebody else has, unhook your reardefroster and put a paper clip into the connector,start the trk, turn on the reardefroster and then try it.
Old Aug 6, 2008 | 10:02 PM
sailorcolin's Avatar
The brake light switch also controls the lock, mine recently went out in a parking lot and i got it to for a little bit by taping the switch while someone looked at the lights and i quickly switched it in to nuetural position.
Old Aug 7, 2008 | 07:01 AM
3rd Gear
My fuse was blown but I have since blown 3 more fuses in last 2 days. Also right rear blinker is out. Any more ideas?
Old Aug 7, 2008 | 04:03 PM
If you keep blowing fuses you have a electrical short somewhere.
Quinn519
Jan 23, 2022 09:44 AM
georgep
Jan 11, 2022 02:14 PM
morzy41
May 25, 2010 07:18 PM
LockedOut
Jan 14, 2008 12:44 AM
