Hi/low floppy
Old Dec 7, 2018 | 03:46 PM
yardpro's Avatar
Default Hi/low floppy
on our 04 disco2 my son was in the back yard shifting from hi to low messing with the truck.
he came in and said it wouldn’t shift.
i went out and lever is very loose. Almost no resistance. It will still work doing difflock..
i assume broken cable which means center console coming out?
Anything common to check first?
Old Dec 7, 2018 | 03:53 PM
Best4x4's Avatar
Check the connection at the TC, it could have had the pin swivel loose or it could have rusted out as well or the cable.
Old Dec 8, 2018 | 07:25 AM
yardpro's Avatar
So I think I found the cause. I need some input from someone familiar with the cable setup.
at the shifter the entire cable, sheath and everything is moving back and forth, sonthe cable is not moving independently inside the sheath.
how does the shifter end of the cable attach to the plate? Looks like a circlip etc. anyone know how it attaches?
Old Dec 8, 2018 | 12:18 PM
acg's Avatar
acg
Minute 7 and after in this video will give you the info:
Old Dec 9, 2018 | 07:09 AM
yardpro's Avatar
Fixed it.
.was the c clip. Went to auto parts and got a c clip for e brake cable. Worked like a champ.
Old Dec 9, 2018 | 08:52 AM
Best4x4's Avatar
Figured that's what it sounded like! Congrats
Brice R. Pecnik
Dec 10, 2018 04:49 AM
andries
Oct 29, 2018 09:14 PM
GBR.R
Sep 23, 2018 12:12 AM
ColoDisco
Jul 26, 2011 06:28 PM
FireUps
May 11, 2011 12:34 PM
