HID Extra Headlight detailed installation
Old Jan 14, 2011 | 01:18 PM
  #21
bosshogt's Avatar
Hi Simann,
Those D2R bulbs look interesting. Looks like it has a black shielding coating on the glass bulb. I assume that helps cut down on the glare. Also looks like it requires an adaptor to fit the standard plugs on the ballasts. I would be interested to see it side by side in my setup with what I have now in the driver's headlight and a D2R bulb in the passengers. The D2R bulb looked keyed similar to the H7 bulb slot I require.
What is the cost of converting a reflector style as I have on my 2003 to a projector? Can it be aimed to project a wide path as I have now? I really like my current setup, but I am always open to hear from people who know more than me.
http://www.google.com/imgres?imgurl=...w=1280&bih=587
Old Jan 15, 2011 | 10:58 AM
  #22
Simann's Avatar
Wink
You can buy adapters to fit D2R bulbs in a D2S housing, they are like $20 a pair. D2R do cut down on glare, they are made for cars that have HID's but do not have projector housings. (2001 Acura CL, early 2000 Mercedes and such).
As well, I would highly suggest you purchase a lower K (kelvin) temperature bulb, 5000K is way too blue and does not give you maximum light output, just a color. OEM is between 3000-4000 K, this will also cut down on the glare factor but still give you that crisp-clear look that you want with HID's.
I will be doing an install sometime soon, I will let you know the parts I use and how I do it. ( I doubt I will retrofit projectors in the housings of my 03', the used pairs of headlamps for these models are way to pricey to have fun with)
Old Jan 15, 2011 | 10:24 PM
  #23
bosshogt's Avatar
My HID lights look much bluer my photos than in person. They really appear white at night and while standing in front of the vehicle. I considered the 4000k bulb temp but the light guide I was referencing looked yellowish and I didn't like that. I guess I could switch these out to the high beam and go for a 4000k on the low beam. I didn't think there would be much difference in color.
detailjohn
Oct 1, 2009 01:33 PM
Torancis_LR
Jul 4, 2009 06:34 PM
scarlettwu
Off Topic
Mar 25, 2009 02:10 AM
tom_meeks@yahoo.com
May 23, 2008 09:48 AM
Lebowski87
Jul 13, 2006 08:40 PM
