HID install
Old Jul 14, 2008 | 07:17 PM
Disco2Guy's Avatar
Default HID install
So after realizing that a pair of Hella 4000's weren't going to fit on the stock brushguard, I purchased a set of 7" HID's from Kragen. Compared to the $670 per light for the Hella version, these were only $120 (on sale). The ballast is inside the lamp housing and came with a wiring harness. The PO installed the factory fogs (also by Hella) and used both the factory fog switch and the one included with the Hella wiring harness. The switch is right next to the side mirror adjuster switch and illuminates green when on. The wires were routed next to the ones for the cb and passed through the same grommet by the brake pedal to get inside. The battery clamp had to be trimmed after getting the Optima Blue Top. The clamp is just wide enough to touch the aux terminal posts.
Old Jul 14, 2008 | 07:26 PM
Disco2Guy's Avatar
Default RE: HID install
I taped them off at first but knew something had to be done when I wanted to use them.
Old Jul 14, 2008 | 07:28 PM
Disco2Guy's Avatar
Are you kidding me??!!
In the box
Old Jul 14, 2008 | 07:29 PM
Disco2Guy's Avatar
Battery clamp
Old Jul 14, 2008 | 07:31 PM
Disco2Guy's Avatar
Low beams
Old Jul 14, 2008 | 07:32 PM
Disco2Guy's Avatar
Low beams w/ HID's
Old Jul 14, 2008 | 07:34 PM
Disco2Guy's Avatar
The HID's installed
robdis96
Feb 22, 2013 07:07 PM
sickws6
Jan 8, 2012 12:48 AM
jbarr89
Mar 1, 2011 08:24 PM
tcbinaflash
May 5, 2010 08:32 PM
scarlettwu
Off Topic
Mar 25, 2009 02:10 AM
