High beam issue
Old Feb 5, 2021 | 08:05 AM
ahab's Avatar
Default High beam issue
The other night was particularly cold and I couldn't get the high beams to stay on in my new-to-me '04. When I pulled the stalk in the highs would light up and the fogs would extinguish however when I released the stalk it would revert back to low beams and fogs. Since I have no history I don't know if this is common for this truck when it's extra cold or a one time occurrence, but once the truck warmed up the high beams "stuck" and began operating normally. In my experience this would indicate a bad high beam relay however going through the ETM, it appears that these headlights aren't wired that way.
Would the next logical step be to swap out the clockspring/stalk assembly or is there a more common electrical problem that would cause this?
Old Feb 5, 2021 | 09:44 AM
Red5's Avatar
I had an old volkswagon that would do the same. In my case it was the switch on the stalk. The grease had gotten old and when it got below freezing, the hard grease would not allow the little spring to drop into the catch to hold the high beam. I cleaned it and re-greased and all was well.
No Doubt
Sep 24, 2017 08:59 PM
redspyder
Nov 4, 2013 11:31 AM
Disco_Dare89
Aug 8, 2008 05:13 PM
LR4LIFE
Nov 6, 2007 10:23 PM
