Hill descent light relay
I know the relay for the Hill Descent is built into the fuse box, but the interior fuse block is very hard to find for a 2000. Any ideas, bypass it, inline relay, ???
the error code is 101:Brake Light Relay Drive Short to Supply on my nano com as well as 81: brake light Relay Short to Supply.
Anybody developed a workaround?
Thanks everyone!
Thanks everyone!
Well... I really do think your only option is a new interior fuse box or repairing yours (which is basically not possible)
You can find one eventually !
I went through this with my old 00 D2
Thought so, nashvegas, but there’s always hope! Really appreciated your extensive write up on this problem but I have a question, actually 2.
Will the fuse block out of a truck with SAI work on mine, which DOES NOT have SAI? I found one for $150 on eBay with the part number 1999/02 LAND ROVER DISCOVERY 2 INTERIOR FUSE BOX PANEL YQE000410 4.0L W/ SAI OEM
And #2, I would assume that a fuse block from a UK TD5 truck will also not work?
Your thoughts/experience on this is greatly appreciated!
Pretty sure SAI vs non SAI doesn’t matter for the fusebox.
As for TD5, I think I was wrong. I just peeked at the parts catalogue -- JLR Classic Parts
(the best one out there btw)
It looks like they are the same - there’s no differentiation between NAS and non NAS or V8 and TD5.
Interestingly, the under bonnet fusebox is definitely different NAS vs non NAS. But not the interior.
Thanks again nashvegas. I also sent a "parts enquiry" to JLR Classic Parts to determine whether or not the TD5 would work in an NAS V8.
Will let you know when they respond, hopefully in a day or two.
And also, once a part is obtained, it's pretty much "plug and play", just unplug everything, obviously one plug or fuse at a time, and plug into the "new" fuse block?
The truck has no leaks but did in times past, so I'm sure corrosion of some sort is the situation.
