Homemade strap wrench for front crank pulley
I don't want to hear any crap about me tapping the starter last year to loosen my front crank bolt.
I re-tightened with 150# torque wrench + 90deg. by blocking the crank with a 2x4 while I had the pan off.
My starter lasted a few good mos. after that & has been replaced, thank you.
So, this time, I took an old spare serp belt, slipped it through an 18" piece of 1-1/4" galv
pipe, put the big loop around my harmonic, the slack end vice-gripped, and loosened the bolt w/ease
so there
luck,greg
so there
luck,greg
I wouldn't mind at all, except I've tried probably 10 times here & elsewhere & the picture fairy won't let me.
I tried with: electric fans, sludge & old gaskets in oil pan, oil,temp,volt gauge install,
difflock R&R, new rollers(stainless) window regs, headlight switch rebuild, etc.
It asks for a url or some damned thing.
I'm old & have little patience left for non-mechanical things
luck,greg
luck,greg
Took me forever and a year to figure out how to post pics.
www.photopbucket.com, set up your free account, upload your pics, go to your album, scroll over the pic you want, find the "IMG CODE" and highlight it, copy the IMG CODE and then paste it into the post.
Press the enter key for spaces between pictures.
kcirtap
Sep 26, 2007 09:39 AM
