Hood prop no more! How to get your hood prop out of the way forever.
Old Aug 7, 2015 | 07:11 PM
  #31
Alex_M's Avatar
Thats great, I might have to do the same in the future instead of switching to a 60 pounder.
I'm flattered!
Old Aug 7, 2015 | 07:19 PM
  #32
Charlie_V's Avatar
So the new plan is two forty pounders???
The mod, original or two forty pounders, is brilliant. But I'm fixating on the fender over the bracket. It is aluminum so I'm either going to beat it down or maybe cut it a little. Any ideas on that?
Old Aug 7, 2015 | 08:28 PM
  #33
Alex_M's Avatar
Yea, I wasn't sure about it at first. Usually I'd just cut it out, but my grandfather came and borrowed his angle grinder back and I didn't have anything to cut it. I just bolted it right back over the mount and it didn't push the fender up or out (surprisingly). I might fix it at some point just so it looks better with the hood open. Might not. Who knows? Haha
Old Aug 8, 2015 | 03:21 PM
  #34
Charlie_V's Avatar
I used bolts on mine so it sits up a little.
I tried to PM you and I can't get it to work on my phone. Can you send me the specs on your cold air intake? My cam arrived so the engine will be ready soon and some jackass glued the breather hose together after breaking it. I broke that and I don't want glue under my "bonnet," so close to my "propshaft" and in view of my "spanners." The replacement price makes me want to commit random/targeted acts of violence, and I like yours better anyway. I want a cone!
Old Aug 8, 2015 | 04:23 PM
  #35
Alex_M's Avatar
I understand that! I don't remember the exact dimensions, I think it was 3.25" diameter but let me check when I get back and I'll throw up some better pictures. I do remember the filter was a k&n e-1009. I'll make a seperate post though so future searchers can find it more easily.
Old Dec 3, 2015 | 08:29 AM
  #36
jamestfl's Avatar
excellent write-up, great work guys. after watching the AB video on replacing the strut for the P38, it looks like the P38 strut is much farther back towards the firewall. that appears to allow for more access / less interference from the strut. any reason we can't mount the strut closer to the firewall on a D2? do you think it would work? thoughts...
Old Dec 3, 2015 | 08:40 AM
  #37
drowssap's Avatar
and if you use the right hand one from a p-38 it has a hold open built into it.
Old Dec 4, 2015 | 01:27 PM
  #38
Charlie_V's Avatar
I think you could move it back a little because the strut seems ready to hold a little more weight. It doesn't threaten to close the hood on my head at all. But, not being an engineer, i'm not sure how much farther back you could go before the leverage of the front of the hood overcame the strut's resistance.
I do something on my rover several times a week and it hasn't been in the way yet. The front one is always in the way and I once bumped the hood with my head, ducked down, and I'd hit it just perfectly to cause the prop to come out so it hit me again! Wow. I get mad just thinking about it so I'll stop there.
Old Mar 23, 2016 | 03:14 PM
  #39
dparham's Avatar
IM IN! what a great writeup! Im going with the 60 lb version... i wonder if two 60 lb would make it hard to shut? initially figured id do 2 of them but then thought hmmm the less n my way the better! especially when its time to change coils or plugs again if I have too!
Old Mar 23, 2016 | 08:51 PM
  #40
bcolins's Avatar
Originally Posted by Joemamma1954
Installed mine on drivers side and doesn't touch anything. Now I am going to order 1 for passenger side. just for grins.
Attachment 26864
Attachment 26865
Had to add "Alex_M prop mod" to signature
Wondering if it will be hard to close the hood with two 60 pounders. Not sure how the math works on these, but, seems like two struts would provide 120 pounds of lifting force,....so,....if the hood weighs 60ish,...then you would have to pull down with 60 pounds of force?
