Horn dead - need help
Old Jan 4, 2011 | 02:01 PM
jw928's Avatar
Question Horn dead - need help
I'm trying to figure out why my horn doesn't work.
I tested the two horns and one of them is dead, but the other horn works when supplied power directly from the battey, so I tried reading the electrical diagrams and testing stuff, but I want to make sure I'm doing it right.
The horn switch on the steering wheel has 12 volts, so I don't think its there.
I have power across fuse 16.
I have power up to the horn relay.
Here is where I get confused. I can't really tell which terminal is which as the relay has the pins labeled 1, 2, 3, 4, and 5, and I was kind of hoping to see 30, 85, 86, 87, and 87a like in the wiring diagram.
Regardless of that, my real question is this. Shouldn't I be able to jumper the relay from the hot to pin 87 and get the horn to work?
Thanks,
John
'02 DII 128K
Old Jan 4, 2011 | 07:29 PM
lordmorpheus's Avatar
I assume the relay itself doesn't have a wiring diagram printed on it? (about 60% of the thousands of relays I've seen have a circuit diagram on one of the sides)
LR3Tuscaloosa
Oct 15, 2014 08:47 PM
bcameron70
Jan 30, 2012 03:09 PM
Russian_Rover
Mar 3, 2010 03:53 AM
03discoman
Dec 8, 2009 04:02 PM
lipadj46
Aug 13, 2009 07:47 PM
