Hot start issues
#31
Thanks guys. I've been driving it the past few days with no issues. Checked the battery connections - they look fine. I'm changing the headlight today - probably the filament as you stated - still have to hit it to get it to work. I'll keep an eye on it. Thanks again for all the input
#32
You have probably already changed the light but, I would check the connector to the the bulb. The OEM connectors are notorious for frying out. This happened on one headlamp and then the other on our disco. Because of the carbonization from the plastic burning, they would work intermittently if we fiddled with the connection a banged on the lamp. Eventually I just cut the wires and spliced in heavier duty connectors immediately behind the bulb.
