How can I tell if the CDL is locked?
Old Feb 28, 2009 | 08:33 PM
Jupiter Rover's Avatar
Default How can I tell if the CDL is locked?
I don't have a lever or a switch. I'm just reaching my hand up there to lock it. But before I do anything, How can I tell I locked it in the "lock" position?
I read somewhere about jacking up a wheel and seeing if it turns. Well in one position it turns a couple inches and in the other position the wheel turns a few more inches than the first.
Old Feb 28, 2009 | 09:16 PM
Camdisco24's Avatar
No matter what, the light should come on telling you its engaged. (upper left of dash display) I did mine by hand as well and the light came on for me. And yes, you should jack up one wheel, you can feel once its locked. I dont think you have to do that but I would think its much easier. Also, you can tell if its on by driving in a circle, it will feel like it is grabbing at the ground sorta.
Old Feb 28, 2009 | 09:43 PM
Well, I just installed the CDL front output housing, and haven't connected the switch that illuminates the dash yet.
I think it is unlocked right now. I switch between the two and in one position it is tougher to turn the wheel.
Old Mar 1, 2009 | 02:22 AM
okdiscoguy's Avatar
The position that is tougher to turn the wheel is locked.
Old Mar 1, 2009 | 02:41 AM
Urban Panzer's Avatar
As already mentioned, the easy way IS to just jack up 1 wheel, if it spins the CDL is not locked, if it dont, it is...........
Old Mar 1, 2009 | 08:17 AM
The steering wheel wont be harder to turn, but it will be harder to drive in a tight circle.
SO if you turn your wheel all the way to the left until it stops and then drive in a circle that circle will be smaller with OUT the CDL locked.
Once it is locked you will have the turning radius as a Amtrack train.
Old Mar 1, 2009 | 09:19 AM
Thanks guys.
turbodave
Mar 29, 2019 07:22 AM
cdm
Apr 11, 2017 11:18 PM
Fivespddisco
Jan 5, 2013 12:38 PM
CANAMDiscovery
Dec 13, 2012 09:31 PM
tornado_735
Mar 19, 2010 08:44 AM
