How can I tell when my Crank Position Sensor is going??
Old Oct 28, 2016 | 12:38 PM
JimmyChooToo's Avatar
Thank you, for passing on the fix. I've had this happen on several vehicles over the years (I'm a fleet mechanic), but normally you'll get a code for low voltage at the ECM. Did your mechanic get a code describing this issue?
This is another reason to keep your battery cables clean and tight. Your vehicle depends heavily on good voltage.
Brian.
No, he didn't but I told him I was getting intermittent M+S flashing from the automatic transmission too, so he decided to check the battery. It solved both problems now. The issue I think in stop and go acceleration/deceleration is the battery cables were moving and causing the RPM to drops.
Walid is a Nice guy. He didn't charge me for anything. I was scared to drive it before, but now I'm more confident things are resolved. I guess I did a bunch of preventive maintenance too, which is always good.
Woody Reems
Jul 14, 2009 08:30 AM
oljohnboy
Mar 30, 2009 08:54 PM
wosmo
Aug 7, 2008 11:24 PM
DiscoOn22s
Apr 19, 2008 05:12 PM
lacruiser
Feb 28, 2008 07:24 AM
