How deep of trouble am I in?
Old Apr 5, 2013 | 08:33 AM
drowssap's Avatar
have the shop machine the heads throw them back on and hopefully your set for another 70k-100k miles.
Old Apr 5, 2013 | 03:04 PM
jfall's Avatar
I had a thin head gasket on my Discovery I. Leaked into the cylinder.
Was not as bad as the example picture.
Does not take much..
1997 Land Rover replace catalytic converter and head gaskets
Old Apr 5, 2013 | 10:30 PM
keoni004's Avatar
Ugh. In addition to my ongoing power problems, while I was under the truck today I noticed what looks like coolant accumulating on the base of the oil pan. Looks like I'll be taking the truck to the shop to figure out WTF is going on, to include a probable head gasket. It's really going to hurt if I need a head gasket *and* a valve job.
Old Apr 5, 2013 | 10:37 PM
Borrow/rent a coolant pressure tester, pump it up to 15 psi, wait 30 minutes, find leak source.
Old Apr 6, 2013 | 12:49 AM
RANDY04D2's Avatar
Default Was there last week.
Most likley bad gasket as water passage just behind that cylinder. My pass side was the same, piston mostly (steam) cleaned. Make sure to get the heads checked for warp/flatness and i reccomend just have the done. Mine were 12-15 thou out. Valve job,decked,cleaned,all threads tapped, $280 at local shop, 1 day...Did i mention this was the second gasket change in 2 yrs? Didnt machine heads the first time... When they warp they twist at the ends (WATER PASSAGES).
Matt_Attack352
Jan 13, 2014 09:55 AM
DeepBlueWater
Jan 9, 2008 09:24 AM
S4poor
Aug 18, 2007 07:12 AM
Camdisco24
Mar 21, 2007 10:03 PM
