How-To: Differential Removal
Old Jul 15, 2020 | 01:50 PM
  #21
Richard Gallant's Avatar
@RoverPA probably got water in there, you might want to open a new thread, but what I would do.
  • Get some cheap gear oil stock weight or a bit lower is fine
  • Fill the diff
  • Block the front tires
  • Jack the back end up -jack stands please
  • Transmission in neutral
  • Spin the back tires a lot by hand - you are avoiding loading up the diff but want to mix the oils to get rid of any remaining contamination
  • Let it sit the spin again 3 or 4 repeats of spin and sit
  • While it sits check your breather and thoroughly clean the diff so you can see any leaks
  • Drain and fill with the good gear oil.
  • You should be good.
Old Jul 15, 2020 | 04:42 PM
  #22
boston4's Avatar
@RoverPA I had the same issue. Drained out the bad oil, filled with cheap gear oil, drove around for a week, then flushed again, filling with slightly more expensive gear oil. The second time I drained it it looked pretty good. Try and let the diff sit for a while (couple hours at least) before draining - that'll help the water settle to the bottom and come out first.
If you haven't already, grab some brass fill plugs for your diffs so you don't need to keep using the terrible plastic plugs - only a matter of time until they strip.
https://www.ebay.com/itm/LAND-ROVER-...T/264083655756
Last edited by boston4; Jul 15, 2020 at 04:44 PM. Reason: New link to Ebay, as the seller I bought from no longer ships from UK-US
Old Jul 15, 2020 | 06:57 PM
  #23
RoverPA's Avatar
Member
Thank you both for your input and kindness. Trying to rebuild my $300 Disco now!
Old Jul 15, 2020 | 06:59 PM
  #24
boston4's Avatar
Welcome to the forum! There’s a ton of information and helpful people here (who are much more knowledgeable than me) - the nice thing is that if something goes wrong, it’s unlikely that you’re the first person who’s had it happen.
Old Jul 17, 2020 | 02:51 AM
  #25
The Deputy's Avatar
Yeah, it's a little more common to see milky diff fluid in the rear axle. Usually the rear axle sees more water; launching boats, backing into ditch to turn around, etc.
Changing the fluid a couple times should clear it up.
Alex_M
Nov 7, 2025 11:55 PM
AirRyan
Jul 5, 2022 11:37 PM
Smarvy
Sep 18, 2017 10:44 AM
dopedawg
Sep 17, 2015 06:31 PM
Antmen
Jul 4, 2013 05:01 PM
