How do I check the Trans Fluid??
Old Dec 28, 2008 | 04:40 PM
lhgdale's Avatar
6th Gear
Default How do I check the Trans Fluid??
Hello, I need to check the trans fluid level on my girlfriends 2000 Discovery. I did a search but couldn't find any info on where and how to check it. Also, if it is low, what type of fluid do I need to put in? Thanks very much.
Old Dec 28, 2008 | 08:33 PM
lhgdale's Avatar
6th Gear
Default RE: How do I check the Trans Fluid??
I would appreciate any help I can get. Thanks
Old Dec 28, 2008 | 08:38 PM
With the truck level and the engine running crawl under the truck, there is a drain and fill plug on the side of the transmission, remove the fill/check plug, the trans fluid should come out of the hole.
If not then add Dexron III, you may need a fluid hand pump.
abran
Apr 27, 2014 06:59 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
GARovee
Aug 22, 2010 09:57 AM
The People Family
Aug 6, 2008 10:32 PM
merleti
Freelander
Aug 28, 2007 05:24 PM
